はじめに
Replacing the battery in the Tommy 20 is a relatively simple replacement, just make sure you have 3 replacement AA batteries ready to go beforehand along with a Phillips #1 Screwdriver! A good first step in any repair goal concerning the Tommy 20!
必要な工具と部品
Remove the single 1mm screw connecting the battery cover to the gun using a Phillips #1 screwdriver.
Lift the cover away from the gun and remove.
Remove all three batteries from compartment by pulling up on the positive end of each battery.
ある他の人がこのガイドを完成しました。
