One by one, de-solder the line of nine wires attached to the docking port board. After pulling out the wires, save them. This is done so that you can solder them into the new docking port board.
Soldering irons are extremely hot and can burn you if you touch them!
If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
