メインコンテンツにスキップ
Asus Zenfone 3 Max Battery Replacement
必要な工具と部品
  1. Asus Zenfone 3 Max Battery Replacement, Back cover: 手順 1、 2の画像 1 Asus Zenfone 3 Max Battery Replacement, Back cover: 手順 1、 2の画像 2
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  2. Asus Zenfone 3 Max Battery Replacement: 手順 2、 1の画像 1
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  3. Asus Zenfone 3 Max Battery Replacement, Battery: 手順 3、 3の画像 1 Asus Zenfone 3 Max Battery Replacement, Battery: 手順 3、 3の画像 2 Asus Zenfone 3 Max Battery Replacement, Battery: 手順 3、 3の画像 3
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  4. Asus Zenfone 3 Max Battery Replacement: 手順 4、 3の画像 1 Asus Zenfone 3 Max Battery Replacement: 手順 4、 3の画像 2 Asus Zenfone 3 Max Battery Replacement: 手順 4、 3の画像 3
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
終わりに
作成者
4人の作成者と共同で作成されました。
Lauren Compton
メンバー登録日: 09/04/19
372 ポイント
4のガイドは作成済み
チーム
University of Alabama, Team S1-G3, Bedsole Fall 2019 University of Alabama, Team S1-G3, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S1G3
4 メンバー
10のガイドは作成済み
3 件のコメント
I need to replace asus zenfone 3 max whole body lcd & what ever the requirements i want to know that it can be replaced or it is dead
Hassan Shahzad - 返信
Part not available on amazon & please bring your store to India, as the market is flooded with a ton of counterfeited products.
Deepank Malhotra - 返信
Asus Zenfone max 3, 5.5 এর ব্র্যাক সেল ও চার্জিং লজিক পাওয়া যাবে কি, জানাবেন প্লিজ
mafijur1122 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 43
今までの合計 3,111
