メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus ZenFone 2 Antenna Replacement
必要な工具と部品
  1. Asus ZenFone 2 Antenna Replacement, Removing the Back Cover: 手順 1、 2の画像 1 Asus ZenFone 2 Antenna Replacement, Removing the Back Cover: 手順 1、 2の画像 2
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
    FixBotに聞いてみる
    コメントを追加
  2. Asus ZenFone 2 Antenna Replacement, Remove the Inner Cover Screws: 手順 2、 1の画像 1
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
    FixBotに聞いてみる
    コメントを追加
  3. Asus ZenFone 2 Antenna Replacement, Remove the Inner Cover: 手順 3、 2の画像 1 Asus ZenFone 2 Antenna Replacement, Remove the Inner Cover: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
    FixBotに聞いてみる
    コメントを追加
  4. Asus ZenFone 2 Antenna Replacement, Remove the Speaker: 手順 4、 1の画像 1
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
    FixBotに聞いてみる
    コメントを追加
  5. Asus ZenFone 2 Antenna Replacement, Remove the Antenna: 手順 5、 2の画像 1 Asus ZenFone 2 Antenna Replacement, Remove the Antenna: 手順 5、 2の画像 2
    • Use a plastic opening tool to gently pry up both ends of the antenna.
    • Carefully remove the antenna wire from the plastic keepers along the side. Note their position for reassembly.
    • The antenna connections can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
    FixBotに聞いてみる
    コメントを追加
終わりに
Reassemble your device by following the instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
37 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Eduardo Nodarse
メンバー登録日: 02/10/16
4,812 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G5
4 メンバー
25のガイドは作成済み
8件のガイドコメント
Hi , do you know if this antenna is the only one? I mean is there another antenna for gps signal?
Thanks
Fabio
fcarminato - 返信 共有
What happens when the cable comes off with the little thing underneath?
I was pretty easily happened to me. I don't even know if it is possible to fix.
Said Tahsin Dane - 返信 共有
It was broken and I soldered it.....afterwards sim1 is not working, but sim2 works well, please help me
Rajkumarfilms - 返信 共有
Could you solve it? I had the fact same problem, sadly on the motherboard end, otherwise I'd just replace the USB board, I tried soldering the cable with no luck, sim 1 still won't work.
Sergio Lapunov - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 16
過去 30 日: 61
今までの合計 41,097
