メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus X551CA WiFi Card Replacement
必要な工具と部品
  1. Asus X551CA WiFi Card Replacement, Keyboard Plate Cover: 手順 1、 1の画像 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    FixBotに聞いてみる
    コメントを追加
  2. Asus X551CA WiFi Card Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    FixBotに聞いてみる
    コメントを追加
  3. Asus X551CA WiFi Card Replacement: 手順 3、 1の画像 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    FixBotに聞いてみる
    コメントを追加
  4. Asus X551CA WiFi Card Replacement: 手順 4、 3の画像 1 Asus X551CA WiFi Card Replacement: 手順 4、 3の画像 2 Asus X551CA WiFi Card Replacement: 手順 4、 3の画像 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    FixBotに聞いてみる
    コメントを追加
  5. Asus X551CA WiFi Card Replacement: 手順 5、 1の画像 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    FixBotに聞いてみる
    コメントを追加
  6. Asus X551CA WiFi Card Replacement, WiFi Card: 手順 6、 1の画像 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. Asus X551CA WiFi Card Replacement: 手順 7、 1の画像 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    FixBotに聞いてみる
    コメントを追加
  8. Asus X551CA WiFi Card Replacement: 手順 8、 1の画像 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Josh
メンバー登録日: 04/10/14
2,970 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G22
5 メンバー
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 27
今までの合計 10,054
