メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus X551CA Power Button Replacement
必要な工具と部品
  1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: 手順 1、 1の画像 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    FixBotに聞いてみる
    コメントを追加
  2. Asus X551CA Power Button Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    FixBotに聞いてみる
    コメントを追加
  3. Asus X551CA Power Button Replacement: 手順 3、 1の画像 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    FixBotに聞いてみる
    コメントを追加
  4. Asus X551CA Power Button Replacement: 手順 4、 3の画像 1 Asus X551CA Power Button Replacement: 手順 4、 3の画像 2 Asus X551CA Power Button Replacement: 手順 4、 3の画像 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    FixBotに聞いてみる
    コメントを追加
  5. Asus X551CA Power Button Replacement: 手順 5、 1の画像 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    FixBotに聞いてみる
    コメントを追加
  6. Asus X551CA Power Button Replacement, Power Button: 手順 6、 1の画像 1
    • Locate the power button in the corner of the keyboard plate cover.
    • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
    FixBotに聞いてみる
    コメントを追加
  7. Asus X551CA Power Button Replacement: 手順 7、 1の画像 1
    • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  8. Asus X551CA Power Button Replacement: 手順 8、 1の画像 1
    • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Josh
メンバー登録日: 04/10/14
2,970 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G22
5 メンバー
15のガイドは作成済み
1件のガイドコメント
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 36
今までの合計 13,348
