はじめに
The display for the tablet is one of the hardest parts to replace as it is attached by glued and you will need a hair dryer. The broken screen affects the display's functionality and will need replacement.
必要な工具と部品
Disconnect the dock and make sure the power is turned off.
Use plastic opening tool to pry screen up and remove from outer casing.
この手順で使用する道具:Tweezers$4.99
Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
Use the same screwdriver to remove two 3mm screws connecting the clips.
Use tweezers to remove two wires connected from the battery to the motherboard.
Use the spudger to remove the battery from the case.
