はじめに
Does your Asus Q525U laptop frequently make strange grinding or ticking sounds? If it does, here is a detailed guide to help fix the issues by replacing the hard drive.
Before beginning this repair, power off your laptop and disconnect from the power adapter.
必要な工具と部品
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
2 の人々がこのガイドを完成させました。
