はじめに
The main battery provides portable power to the laptop. Without the battery, the laptop cannot stay powered on without a power cord. Make sure to select a compatible battery for this laptop when replacing it.
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
ある他の人がこのガイドを完成しました。
