メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus Eee PC 1000HE Keyboard Replacement
必要な工具と部品
  1. Asus Eee PC 1000HE Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Lay the laptop down with the bottom facing upwards.
    • Locate the two battery lock slide tabs.
    FixBotに聞いてみる
    コメントを追加
  2. Asus Eee PC 1000HE Keyboard Replacement: 手順 2、 2の画像 1 Asus Eee PC 1000HE Keyboard Replacement: 手順 2、 2の画像 2
    • Slide the tabs outward to unlock the battery.
    • The right tab will remain in the unlocked position while the left tab must be held.
    • While holding the left tab outward, slide the battery away from you to remove it.
    FixBotに聞いてみる
    コメントを追加
  3. Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 手順 3、 3の画像 1 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 手順 3、 3の画像 2 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 手順 3、 3の画像 3
    • The keyboard will still be attached to the body of the netbook at the conclusion of this step through a ribbon cable located at the bottom edge of the keyboard. Improper removal may result in damage to your device.
    • Identify the four connection points holding the top of the keyboard to the main body of the netbook. To remove the keyboard, use the spudger to unhook the keyboard upwards at these points.
    • The keyboard will become more disconnected as you use the spudger at each connection point.
    FixBotに聞いてみる
    コメントを追加
  4. Asus Eee PC 1000HE Keyboard Replacement: 手順 4、 3の画像 1 Asus Eee PC 1000HE Keyboard Replacement: 手順 4、 3の画像 2 Asus Eee PC 1000HE Keyboard Replacement: 手順 4、 3の画像 3
    • Flip the keyboard over by pulling the top edge of the keyboard away from the netbook body, using the bottom edge as a hinge point.
    • Locate the opaque strip, or ribbon cable, connecting the back of the keyboard to the hardware of the netbook.
    • To disconnect the ribbon cable, use a plastic opening tool to pull each side of the black plastic strip, located below the ribbon cable, away from the ribbon cable.
    • The black strip will disconnect completely from the ribbon cable. The keyboard will then be detached from the netbook's body and can be safely removed.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mike Glenn
メンバー登録日: 03/21/16
1,026 ポイント
8のガイドは作成済み
チーム
Clemson, Team 6-2, Benson Spring 2016 Clemson, Team 6-2, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S6G2
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 1,446
