メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Aroma ARC-914SBD LED Lights Replacement
必要な工具と部品
  1. Aroma ARC-914SBD LED Lights Replacement, Lid: 手順 1、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement, Lid: 手順 1、 2の画像 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
    FixBotに聞いてみる
    コメントを追加
  2. Aroma ARC-914SBD LED Lights Replacement: 手順 2、 1の画像 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
    FixBotに聞いてみる
    コメントを追加
  3. Aroma ARC-914SBD LED Lights Replacement: 手順 3、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement: 手順 3、 2の画像 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
    FixBotに聞いてみる
    コメントを追加
  4. Aroma ARC-914SBD LED Lights Replacement: 手順 4、 3の画像 1 Aroma ARC-914SBD LED Lights Replacement: 手順 4、 3の画像 2 Aroma ARC-914SBD LED Lights Replacement: 手順 4、 3の画像 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
    FixBotに聞いてみる
    コメントを追加
  5. Aroma ARC-914SBD LED Lights Replacement, Push Button Interface: 手順 5、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement, Push Button Interface: 手順 5、 2の画像 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry the bottom edge of this piece outward (away from the stainless steel side) about 1/4 inch to pull the tab out of it's hole. Once the bottom is pried out a bit, the tab can be seen from the bottom. Press up on the tab with a screwdriver.
    FixBotに聞いてみる
    コメントを追加
  6. Aroma ARC-914SBD LED Lights Replacement: 手順 6、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement: 手順 6、 2の画像 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
    FixBotに聞いてみる
    コメントを追加
  7. Aroma ARC-914SBD LED Lights Replacement: 手順 7、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement: 手順 7、 2の画像 2
    • Using a Phillips head screwdriver, size PH2, remove screws from the control module to expose wired connections.
    FixBotに聞いてみる
    コメントを追加
  8. Aroma ARC-914SBD LED Lights Replacement: 手順 8、 1の画像 1
    • Unplug the interface from control module.
    FixBotに聞いてみる
    コメントを追加
  9. Aroma ARC-914SBD LED Lights Replacement: 手順 9、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement: 手順 9、 2の画像 2
    • Remove the two screws holding the cardboard cover over the Interface using a Phillips head screwdriver, size PH2.
    FixBotに聞いてみる
    コメントを追加
  10. Aroma ARC-914SBD LED Lights Replacement: 手順 10、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement: 手順 10、 2の画像 2
    • Using a Phillips head screwdriver, size PH2, remove the four screws holding the interface in place.
    FixBotに聞いてみる
    コメントを追加
  11. Aroma ARC-914SBD LED Lights Replacement, LED Lights: 手順 11、 2の画像 1 Aroma ARC-914SBD LED Lights Replacement, LED Lights: 手順 11、 2の画像 2
    • These pictures identify the LED's along with their corresponding solder points through the back of the circuit board.
    FixBotに聞いてみる
    コメントを追加
  12. Aroma ARC-914SBD LED Lights Replacement: 手順 12、 1の画像 1
    • Heat each point with the soldering iron while pulling the LED out from the front in order to remove the lights. The arrow in the picture points to the + sign above the left solder point. Each of the LED solder points will have one. LED's are polarity sensitive; therefore, the positive pin on the new LED must match up to the positive solder point.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Brandon Nieves
メンバー登録日: 09/04/15
956 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 2-3, Sullivan Fall 2015 USF Tampa, Team 2-3, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S2G3
3 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 29
今までの合計 760
