メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Archos 5 Screen Replacement
必要な工具と部品
    1. Archos 5 Screen Replacement, Screen: 手順 1、 1の画像 1
      • Please be sure that your device is powered off before attempting any repairs.
      • Please be aware that any further steps could possibly void the warranty of your Archos 5.
      FixBotに聞いてみる
      コメントを追加
    2. Archos 5 Screen Replacement: 手順 2、 2の画像 1 Archos 5 Screen Replacement: 手順 2、 2の画像 2
      • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
      • Use the screwdriver(PH000) to remove the screws located under the pads.
      • Lift the stand in order to get to the fourth screw.
      FixBotに聞いてみる
      コメントを追加
    3. Archos 5 Screen Replacement: 手順 3、 2の画像 1 Archos 5 Screen Replacement: 手順 3、 2の画像 2
      • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
      • Once all sides of the device are pried open, gently open the device .
      • Be careful not to tear the foil which connects the LCD screen to the motherboard!
      FixBotに聞いてみる
      コメントを追加
    4. Archos 5 Screen Replacement: 手順 4、 2の画像 1 Archos 5 Screen Replacement: 手順 4、 2の画像 2
      • Once you have opened your device, fold the screen away from the battery.
      • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
      • Use a plastic spudger instead of a metal spudger!
      FixBotに聞いてみる
      コメントを追加
    5. Archos 5 Screen Replacement: 手順 5、 2の画像 1 Archos 5 Screen Replacement: 手順 5、 2の画像 2
      • Using the plastic opening tool, lift the touch pad away from the cracked screen
      • Be careful not to pull or tear the small film/wires as shown in the picture. These are vital to connecting the glass screen and the LCD screen.
      FixBotに聞いてみる
      コメントを追加
    6. Archos 5 Screen Replacement: 手順 6、 2の画像 1 Archos 5 Screen Replacement: 手順 6、 2の画像 2
      • Lift the cracked screen off of your Archos 5 using the regular plastic spudger.
      • Be careful not to rip or tear the film connecting the glass screen and the LCD screen.
      FixBotに聞いてみる
      コメントを追加
    7. Archos 5 Screen Replacement: 手順 7、 1の画像 1
      • Peel the plastic screen away from your shattered glass screen, and replace with your new glass screen.
      • The film connecting the glass screen and the LCD screen is attached the plastic and will peel away with it. Be careful not to rip or tear it.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Ally Hummel
メンバー登録日: 09/22/15
381 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 1-5, Sydow campbell Fall 2015 University of Alabama, Team 1-5, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G5
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 33
今までの合計 2,633
