メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple Studio Display M2454 Main Computer Cable Replacement
必要な工具と部品
    1. Apple Studio Display M2454 Main Computer Cable Replacement, Main Computer Cable: 手順 1、 1の画像 1
      • First, the back panel needs to be removed to access the cable connectors.
      • Locate the three 2mm hex screws located on the top of the stand and remove them.
      • Now locate and remove the four 2mm hex screws on the corners of the back panel.
      • Now remove the back panels while pulling the cable through them without damaging either part.
      FixBotに聞いてみる
      コメントを追加
    2. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 2、 1の画像 1
      • Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
      • Now remove the two other philips screws located below the cable with the philips head screwdriver.
      • With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
      • Pull the metal plate away.
      FixBotに聞いてみる
      コメントを追加
    3. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 3、 1の画像 1
      • Locate and remove the four #2 phillips screws located on the corners of the stand bracket, using the phillips head screwdriver.
      • Pull bracket away from monitor.
      FixBotに聞いてみる
      コメントを追加
    4. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 4、 1の画像 1
      • Remove the cable hold-down with #2 phillips head screwdriver.
      FixBotに聞いてみる
      コメントを追加
    5. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 5、 1の画像 1
      • Remove the screw at the bottom of the plastic bracket, using #2 phillips head screwdriver.
      • Pull the plastic bracket free.
      • Note the plastic pegs lining the bracket up with the monitor.
      FixBotに聞いてみる
      コメントを追加
    6. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 6、 1の画像 1
      • Remove tape holding down the white connector to the LCD main board.
      FixBotに聞いてみる
      コメントを追加
    7. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 7、 1の画像 1
      • With tape removed, the connections on the LCD main board can be disconnected.
      • First, remove the single hold-down using the philips head screwdriver.
      • Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
      • Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
      • The tabs can easily break off, be extra careful
      • Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
      FixBotに聞いてみる
      コメントを追加
    8. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 8、 1の画像 1
      • Now remove the connection not on the LCD Main Board by pulling back the tape holding the wires down first.
      • Remove the connector by hand.
      FixBotに聞いてみる
      コメントを追加
    9. Apple Studio Display M2454 Main Computer Cable Replacement: 手順 9、 1の画像 1
      • Finally, the main cable can be replaced by pulling the old cable away and repeating the previous steps in reverse with a new, working main cable.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Dylan Perry
メンバー登録日: 01/20/10
177 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G27
4 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 47
今までの合計 6,482
