メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apex Tablet 7 Camera Replacement
必要な工具と部品
    1. Apex Tablet 7 Camera Replacement, Back Panel: 手順 1、 1の画像 1
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      FixBotに聞いてみる
      コメントを追加
    2. Apex Tablet 7 Camera Replacement: 手順 2、 2の画像 1 Apex Tablet 7 Camera Replacement: 手順 2、 2の画像 2
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      FixBotに聞いてみる
      コメントを追加
    3. Apex Tablet 7 Camera Replacement: 手順 3、 2の画像 1 Apex Tablet 7 Camera Replacement: 手順 3、 2の画像 2
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      FixBotに聞いてみる
      コメントを追加
    4. Apex Tablet 7 Camera Replacement: 手順 4、 1の画像 1
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      FixBotに聞いてみる
      コメントを追加
    5. Apex Tablet 7 Camera Replacement: 手順 5、 1の画像 1
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      FixBotに聞いてみる
      コメントを追加
    1. Apex Tablet 7 Camera Replacement, Camera: 手順 6、 2の画像 1 Apex Tablet 7 Camera Replacement, Camera: 手順 6、 2の画像 2
      • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
      FixBotに聞いてみる
      コメントを追加
    2. Apex Tablet 7 Camera Replacement: 手順 7、 1の画像 1
      • Flip the black latch over the gold cable to the upright position in order to release the cable.
      FixBotに聞いてみる
      コメントを追加
    3. Apex Tablet 7 Camera Replacement: 手順 8、 1の画像 1
      • Carefully remove the cable from the circuit by pulling it straight out.
      FixBotに聞いてみる
      コメントを追加
    4. Apex Tablet 7 Camera Replacement: 手順 9、 1の画像 1
      • Pull out the camera. There should not be any more connections holding it in place.
      • Reconnect the replacement camera.
      FixBotに聞いてみる
      コメントを追加
終わりに
To place the new part and reassemble your device, follow these instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Steven Gutzwiller
メンバー登録日: 03/20/15
480 ポイント
3のガイドは作成済み
チーム
Baylor, Team 2-2, Grigsby Spring 2015 Baylor, Team 2-2, Grigsby Spring 2015人のメンバー
BU-GRIGSBY-S15S2G2
4 メンバー
25のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 27
今までの合計 727
