はじめに
Is your Anker Soundcore Space Q45 battery not holding a charge like it used to, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few simple steps. This guide will require you to remove the outer casing of the left headphone to access the battery.
必要な工具と部品
Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
Clips at 3 o'clock, 7 o'clock and 11 o'clock
Image shows right headphone, battery is in left.
5 の人々がこのガイドを完成させました。
6件のガイドコメント
Hi. The microphone quality of Anker Q45 is terrible. Do you think it is possible to replace de microphone for a better one?
Perry Picoli - 返信 共有
What battery model?
Look for a 632832, but you might have trouble acquiring a single unit, unless you're okay with waiting a month or two with aliexpress shipping
