メインコンテンツにスキップ
Anker SoundCore 2 Charging Port Replacement
必要な工具と部品
  1. Anker SoundCore 2 Charging Port Replacement, Front Panel: 手順 1、 2の画像 1 Anker SoundCore 2 Charging Port Replacement, Front Panel: 手順 1、 2の画像 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Charging Port Replacement, Motherboard: 手順 2、 3の画像 1 Anker SoundCore 2 Charging Port Replacement, Motherboard: 手順 2、 3の画像 2 Anker SoundCore 2 Charging Port Replacement, Motherboard: 手順 2、 3の画像 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Charging Port Replacement: 手順 3、 3の画像 1 Anker SoundCore 2 Charging Port Replacement: 手順 3、 3の画像 2 Anker SoundCore 2 Charging Port Replacement: 手順 3、 3の画像 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Charging Port Replacement, Charging Port: 手順 4、 2の画像 1 Anker SoundCore 2 Charging Port Replacement, Charging Port: 手順 4、 2の画像 2
    • Desolder the charging port from the motherboard and solder a new one on.
    • For help with soldering and desoldering, follow this guide.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tripp Lersch
メンバー登録日: 01/14/21
402 ポイント
4のガイドは作成済み
チーム
4 件のコメント
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - 返信
Where can i get a replacement charging Port?
A K - 返信
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - 返信
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 95
今までの合計 1,791
