メインコンテンツにスキップ
Anker 2.4G Wireless Mouse Left and Right Button Replacement
必要な工具と部品
  1. Anker 2.4G Wireless Mouse Left and Right Button Replacement, Left and Right Buttons: 手順 1、 1の画像 1
    • Peel off the stickers. This will reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 2、 1の画像 1
    • Remove the four screws using a Phillips #0 screwdriver.
  3. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 3、 2の画像 1 Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 3、 2の画像 2
    • Use a spudger to pry apart the upper and lower housing of the mouse.
  4. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 4、 1の画像 1
    • Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
    • Pull as far up on the wires as possible. Be careful not to rip the wires by applying too much force.
  5. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 5、 1の画像 1
    • Remove the scroll wheel from the mother board by pulling it to the left.
    • This may take some force to remove. Make sure to pull the scroll wheel parallel to the board, not perpendicularly.
  6. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 6、 1の画像 1
    • Pull the mother board gently away from the plastic housing.
  7. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 7、 2の画像 1 Anker 2.4G Wireless Mouse Left and Right Button Replacement: 手順 7、 2の画像 2
    • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
終わりに
2 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Vincent Lee
メンバー登録日: 01/23/14
361 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G39
4 メンバー
16のガイドは作成済み
2 件のコメント
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - 返信
where can these replacement button switches be purchased….thanks ric
Ric Scambler - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 38
今までの合計 4,456
