メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AmazonBasics B0050BPWBQ On/Off Switch Replacement
必要な工具と部品
    1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: 手順 1、 2の画像 1 AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: 手順 1、 2の画像 2
      • The unit head needs to be switched to the off position and unplugged before any disassembly.
      • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
      • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
      FixBotに聞いてみる
      コメントを追加
    2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: 手順 2、 2の画像 1 AmazonBasics B0050BPWBQ On/Off Switch Replacement: 手順 2、 2の画像 2
      • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
      • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
      FixBotに聞いてみる
      コメントを追加
    3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: 手順 3、 1の画像 1
      • Lay the back panel away from the front panel on a flat surface.
      • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
      FixBotに聞いてみる
      コメントを追加
    4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: 手順 4、 2の画像 1 AmazonBasics B0050BPWBQ On/Off Switch Replacement: 手順 4、 2の画像 2
      • Find the green control board that is located next to the shredding motor.
      • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
      • You may need to move wires over to find the screws.
      FixBotに聞いてみる
      コメントを追加
    1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: 手順 5、 3の画像 1 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: 手順 5、 3の画像 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: 手順 5、 3の画像 3
      • Pull the front panel away from the shredding unit.
      • Locate the black On/Off switch attached to the front panel where the control board was once attached.
      • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Natalie Meert
メンバー登録日: 02/11/16
741 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 2-4, Baechle Spring 2016 IUPUI, Team 2-4, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G4
4 メンバー
8のガイドは作成済み
1件のガイドコメント
Does anyone know where to buy a replacement switch?
Shawn - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 37
今までの合計 2,967
