はじめに
This guide shows how to replace an activation sensor that is no longer functional. The activation sensor is located in the middle of the feed slot so this guide will show you how to access this in order to replace it.
必要な工具と部品
Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
Locate the large white gears on the side of the shredding unit.
Remove two 15 mm Phillips #1 screws that hold the motor in place.
Locate the three washers on the metal triangle piece.
Remove the three washers using two metal spudgers. To do this, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
Pull the metal triangle away from the gears.
Remove the last 15 mm Phillips #1 screw from the plastic triangle piece on the side of the shredding unit.
ある他の人がこのガイドを完成しました。
