メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Fire Phone Display Replacement
必要な工具と部品
  1. Amazon Fire Phone Display Replacement, Tape the screen: 手順 1、 1の画像 1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
    FixBotに聞いてみる
    コメントを追加
  2. Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: 手順 2、 3の画像 1 Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: 手順 2、 3の画像 2 Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: 手順 2、 3の画像 3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. Amazon Fire Phone Display Replacement: 手順 3、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 3、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 3、 3の画像 3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
    FixBotに聞いてみる
    コメントを追加
  4. Amazon Fire Phone Display Replacement, Remove Bracket: 手順 4、 1の画像 1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    FixBotに聞いてみる
    コメントを追加
  5. Amazon Fire Phone Display Replacement, Disconnect Battery: 手順 5、 1の画像 1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    FixBotに聞いてみる
    コメントを追加
  6. Amazon Fire Phone Display Replacement, Micro-USB Port: 手順 6、 2の画像 1 Amazon Fire Phone Display Replacement, Micro-USB Port: 手順 6、 2の画像 2
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
    FixBotに聞いてみる
    コメントを追加
  7. Amazon Fire Phone Display Replacement: 手順 7、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 7、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 7、 3の画像 3
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
    FixBotに聞いてみる
    コメントを追加
  8. Amazon Fire Phone Display Replacement: 手順 8、 1の画像 1
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
    FixBotに聞いてみる
    コメントを追加
  9. Amazon Fire Phone Display Replacement: 手順 9、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 9、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 9、 3の画像 3
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
    FixBotに聞いてみる
    コメントを追加
  10. Amazon Fire Phone Display Replacement: 手順 10、 2の画像 1 Amazon Fire Phone Display Replacement: 手順 10、 2の画像 2
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
    FixBotに聞いてみる
    コメントを追加
  11. Amazon Fire Phone Display Replacement: 手順 11、 1の画像 1
    • Lift off bottom plastic piece with flat antenna cables
    FixBotに聞いてみる
    コメントを追加
  12. Amazon Fire Phone Display Replacement, Display: 手順 12、 1の画像 1
    • We recommend you clean your microwave before preceding to heat up the iOpener.
    • Place the iOpener in the center of the microwave.
    • Heat the iOpener for thirty seconds.
    • Be careful not to overheat the iOpener and always wait at least three minutes before reheating the iOpener
    FixBotに聞いてみる
    コメントを追加
  13. Amazon Fire Phone Display Replacement: 手順 13、 1の画像 1
    • Lay the iOpener on side 1 of the phone for 90 seconds before attempting to open the front panel
    FixBotに聞いてみる
    コメントを追加
  14. Amazon Fire Phone Display Replacement: 手順 14、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 14、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 14、 3の画像 3
    • Using the Suction Cup to slightly lift the screen, pry one opening pick into side of the phone.
    • Insert another opening pick next to the first one.
    • Slowly slide the two Picks to the corners of the phone.
    FixBotに聞いてみる
    コメントを追加
  15. Amazon Fire Phone Display Replacement: 手順 15、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 15、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 15、 3の画像 3
    • Place the iOpener on side 2 of the phone for 90 seconds.
    • Insert another pick into side 2 of the phone.
    • Slowly slide the pick to the next corner.
    • If necessary, reheat the iOpener. Don't reheat it more than once every 3 minutes.
    FixBotに聞いてみる
    コメントを追加
  16. Amazon Fire Phone Display Replacement: 手順 16、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 16、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 16、 3の画像 3
    • Place the iOpener on the 3rd side of the phone for 90 seconds.
    • Place a pick in the corner of the phone.
    • Slowly slide the the pick to the opposite corner of the phone.
    FixBotに聞いてみる
    コメントを追加
  17. Amazon Fire Phone Display Replacement: 手順 17、 3の画像 1 Amazon Fire Phone Display Replacement: 手順 17、 3の画像 2 Amazon Fire Phone Display Replacement: 手順 17、 3の画像 3
    • Place the iOpener on the last edge of the phone for 90 seconds.
    • Place the pick in the corner.
    • Slowly slide the pick to the opposite corner.
    FixBotに聞いてみる
    コメントを追加
  18. Amazon Fire Phone Display Replacement: 手順 18、 1の画像 1
    • Carefully separate the screen from the front panel of the phone by inserting the picks farther towards the center and pulling the screen off.
    • Slowly and carefully do this to avoid breaking, bending or shattering the screen.
    • If part of the screen isn't easily coming off try reheating the iOpener and placing it on the problem area.
    FixBotに聞いてみる
    コメントを追加
  19. Amazon Fire Phone Display Replacement: 手順 19、 1の画像 1
    • Remove the screen slowly.
    • Pull the cable out of the hole carefully.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Lissandra Ilcyn
メンバー登録日: 10/05/15
889 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G7
5 メンバー
20のガイドは作成済み
1件のガイドコメント
how to replace touch?
coolsaad2010 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 74
今までの合計 6,006
