はじめに
If you give the amazon echo studio some voice commands, and it does not respond to them, and/or if you noticed the lightboard does not light up anymore, this guide will help you replace the lightboard.
必要な工具と部品
Flip the device upside down.
Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
Remove the two screws located across from each other on the outside of the plastic ring shown.
Remove the plastic outer ring that hugs the inside of the edges of the device.
On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
First, locate the six 10 mm screws at the top of the inside of the shell and unscrew them with a T10 Torx screwdriver.
After removing the six screws from the inside, lift the top speaker cover.
ある他の人がこのガイドを完成しました。
