メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Echo Show Screen Replacement
必要な工具と部品
    1. Amazon Echo Show Screen Replacement, Screen: 手順 1、 3の画像 1 Amazon Echo Show Screen Replacement, Screen: 手順 1、 3の画像 2 Amazon Echo Show Screen Replacement, Screen: 手順 1、 3の画像 3
      • Use the plastic opening tool to gently lift the plastic protector from screen.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Echo Show Screen Replacement: 手順 2、 2の画像 1 Amazon Echo Show Screen Replacement: 手順 2、 2の画像 2
      • Once the protector is lifted from screen, use the plastic opening tool to remove the actual screen from device, using an opening near the bottom left corner.
      • Once both parts are removed from the device, you can insert the new screen itself. Make sure that the digitizer cable of the new screen is placed within the recess when replacing the screen.
      • If necessary, use adhesive to more firmly secure the LCD or the protector screen to the rest of the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Christina Simone
メンバー登録日: 10/24/18
576 ポイント
4のガイドは作成済み
6件のガイドコメント
Where do you dug replacement glass for
the echo show 5
gravytray - 返信 共有
There is no glass replacement. I just got off the phone with Amazon Customer Support and they do not manufacture glass replacement pieces. In other words, if you break the glass you are out of luck. I've submitted feedback (via telephone customer support) for Amazon to begin producing replacement parts and urge you to do the same. Problem with being an early adapter is that what is normal protocol for business (in this case making replacement parts) is not yet developed.
Unfortunate since now I have a $230 awesome piece of tech that has a shattered screen. Customer service gave me $30 :/
djpinna - 返信 共有
You REALLY should remind folks that the front screen is a digitizer and has a delicate ribbon cable coming off it about 1 1/2 inches from the left lower corner. If you use a pry tool there, you’ll slice the ribbon and ruin the digitizer. Don’t ask me how I know! I now have an Echo show with no touch screen capability. Lower left corner about an inch and a half toward the center. No glue there but if you slide a spudger along there, you’ll cut it for sure. Word to the wise……
n3tqv - 返信 共有
Yes…. &&^&^$^ ribbon! Where do you get a digitizer. And a power and speaker supply
Ryan Anderson - 返信 共有
Any info on the brand / model number for the digitizer assembly, and any info on how to drive it? I would like to replace the “brains” of my Echo Show 10 2nd Gen with something like a Raspberry Pi. (Not too concerned about Touch, Sound, Mic, though if it was possible to make those work, all the better. Really just need video.). TIA!
Jonathan Yankovich - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 90
今までの合計 15,646
