メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Echo Show 5-Megapixel Camera Replacement
必要な工具と部品
  1. Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: 手順 1、 2の画像 1 Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: 手順 1、 2の画像 2
    • Use the plastic opening tool to gently lift the plastic protector from the screen.
    FixBotに聞いてみる
    コメントを追加
  2. Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 2、 2の画像 1 Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 2、 2の画像 2
    • After the protector has been removed, use your hands to gently remove the taped-in rubber foot from device.
    FixBotに聞いてみる
    コメントを追加
  3. Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 3、 1の画像 1
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
    FixBotに聞いてみる
    コメントを追加
  4. Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 4、 3の画像 1 Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 4、 3の画像 2 Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Lay the front section flat, with the screen down.
    FixBotに聞いてみる
    コメントを追加
  5. Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 5、 3の画像 1 Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 5、 3の画像 2 Amazon Echo Show 5-Megapixel Camera  Replacement: 手順 5、 3の画像 3
    • Remove two 1mm T5 Torx screws.
    • Once the screws have been removed, you can easily remove the camera from the device.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Christina Simone
メンバー登録日: 10/24/18
576 ポイント
4のガイドは作成済み
1件のガイドコメント
Can not reset amazon echo show model MW46WB tried everything any suggestions
Skippy Gessler - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 35
今までの合計 2,549
