メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AlphaSmart Pro Individual Key Replacement
必要な工具と部品
    1. AlphaSmart Pro Individual Key Replacement, Removing a Key: 手順 1、 2の画像 1 AlphaSmart Pro Individual Key Replacement, Removing a Key: 手順 1、 2の画像 2
      • Insert the plastic opening tool or spudger into the side of the key you wish to remove, and press downward on the far end of the tool to pry the key up.
      • You may also pry the key up by simply using your finger and/or fingernail, however, it is easier to use an opening tool.
      FixBotに聞いてみる
      コメントを追加
    2. AlphaSmart Pro Individual Key Replacement, The Spacebar Spring: 手順 2、 1の画像 1
      • If the key you are removing is the spacebar (like you see pictured here), you should find a single spring placed on one of two circular spots located one the right and left side underneath the key.
      • Remove the spring and place it to the side so it doesn't get lost.
      • It does not matter which of the two circular spots the spring is on.
      • There is only one spring per spacebar. If the spring is missing, don't worry — the spacebar will work fine without it — but it will work better when the spring is attached.
      FixBotに聞いてみる
      コメントを追加
    3. AlphaSmart Pro Individual Key Replacement, Removing Other Keys: 手順 3、 1の画像 1
      • If you wish to remove another key besides the spacebar, the same methods of removal apply.
      • You should hear a "popping" or "snapping" sound when the key has been removed.
      • Unlike the spacebar key, all the other keys do not have a spring.
      FixBotに聞いてみる
      コメントを追加
    4. AlphaSmart Pro Individual Key Replacement, Replacement: 手順 4、 2の画像 1 AlphaSmart Pro Individual Key Replacement, Replacement: 手順 4、 2の画像 2
      • To replace the key(s), simply align the center cylindrical post(s) with the center holes.
      • Use your index finger to press down on the middle of the key. You should hear it "click" into place.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Katy Beth Culp
メンバー登録日: 10/13/14
1 ポイント
2のガイドは作成済み
チーム
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G1
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 47
今までの合計 2,042
