メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware X51 R1/R2/R3 RAM Replacement
必要な工具と部品
  1. Alienware X51 R1/R2/R3 RAM Replacement, Remove Panel Screw: 手順 1、 1の画像 1
    • First, turn the computer so you can see the rear panel. Remove the small screw to the right (or above, if the system is on its side) of the audio jacks.
    • Once the screw is removed, use both hands to push the side panel down and towards the front of the case.
    FixBotに聞いてみる
    コメントを追加
  2. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect LED Control Cable: 手順 2、 1の画像 1
    • Lift the side panel off, and gently flip it over the top of the system, being careful not to break the LED control cable. Unplug its connector and set the case panel to the side.
    FixBotに聞いてみる
    コメントを追加
  3. Alienware X51 R1/R2/R3 RAM Replacement, Remove Fan Screws: 手順 3、 1の画像 1
    • Next, remove the screws securing the plastic air re-director (not shown in picture) to the fan, and gently lift it out of the case. Set aside and move to the next step.
    FixBotに聞いてみる
    コメントを追加
  4. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect/Remove the DVD Drive: 手順 4、 1の画像 1
    • Unplug the SATA cable at the base of the DVD drive circled in blue. This cable will have a lot of tension on it, but do not worry. Just be careful not to yank on it too much.
    • You will then unscrew the screw securing the DVD drive to the case (circled in red). Once the screw is removed, remove the DVD drive and set to the side.
    FixBotに聞いてみる
    コメントを追加
  5. Alienware X51 R1/R2/R3 RAM Replacement: 手順 5、 1の画像 1
    • Now, push the white latch (circled in red) DOWN and pull the ram card straight up to a ~45 degree angle. Pull up and out, towards the latch side, and set aside.
    FixBotに聞いてみる
    コメントを追加
  6. Alienware X51 R1/R2/R3 RAM Replacement, Insert New Ram Card: 手順 6、 1の画像 1
    • You will insert the new DIMM. Push the side opposite to the latch in first, being sure that the notch in the connector matches the location on the ram DIMM.
    • Insert at a ~45 degree angle and push straight down into the socket, being sure that the latch clicks.
    • DO NOT FORCE THE DIMM IN. Rotate the card and try again if the card will not go into the port.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Daniel Niles
メンバー登録日: 02/12/16
163 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 5-6, Prince Winter 2016 Pasco Hernando, Team 5-6, Prince Winter 2016人のメンバー
PHSC-PRINCE-W16S5G6
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 66
今までの合計 7,027
