メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware M17x Motherboard Replacement
必要な工具と部品
    1. Alienware M17x Motherboard Replacement, Battery: 手順 1、 2の画像 1 Alienware M17x Motherboard Replacement, Battery: 手順 1、 2の画像 2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      FixBotに聞いてみる
      コメントを追加
    2. Alienware M17x Motherboard Replacement: 手順 2、 1の画像 1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      FixBotに聞いてみる
      コメントを追加
    3. Alienware M17x Motherboard Replacement: 手順 3、 1の画像 1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      FixBotに聞いてみる
      コメントを追加
    4. Alienware M17x Motherboard Replacement: 手順 4、 2の画像 1 Alienware M17x Motherboard Replacement: 手順 4、 2の画像 2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      FixBotに聞いてみる
      コメントを追加
    1. Alienware M17x Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
      • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
      • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
      • Twelve 5.5 mm Phillips #0 main frame screws.
      • Six 3.5 mm Phillips #0 fan screws.
      • Four 3.5 mm Phillips #0 internal compartment screws.
      • Eight 3.5 mm Phillips #0 Hard Drive screws.
      • Four 3.5 mm Phillips #0 CD Drive screws.
      • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
      FixBotに聞いてみる
      コメントを追加
    2. Alienware M17x Motherboard Replacement: 手順 6、 3の画像 1 Alienware M17x Motherboard Replacement: 手順 6、 3の画像 2 Alienware M17x Motherboard Replacement: 手順 6、 3の画像 3
      • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
      • Use a plastic opening tool to pry the keyboard from the base of the computer.
      FixBotに聞いてみる
      コメントを追加
    3. Alienware M17x Motherboard Replacement: 手順 7、 1の画像 1
      • Remove five 3.5 mm Phillips #0 screws from the motherboard.
      • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
      • Lift the motherboard at an angle and remove it from the computer base.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Mosier Locke
メンバー登録日: 09/27/18
783 ポイント
5のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 35
今までの合計 2,484
