メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware M17-R1 Screen Lock Assembly Replacement
必要な工具と部品
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: 手順 1、 1の画像 1
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
    FixBotに聞いてみる
  2. Alienware M17-R1 Screen Lock Assembly Replacement: 手順 2、 2の画像 1 Alienware M17-R1 Screen Lock Assembly Replacement: 手順 2、 2の画像 2
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
    FixBotに聞いてみる
  3. Alienware M17-R1 Screen Lock Assembly Replacement: 手順 3、 2の画像 1 Alienware M17-R1 Screen Lock Assembly Replacement: 手順 3、 2の画像 2
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
    FixBotに聞いてみる
  4. Alienware M17-R1 Screen Lock Assembly Replacement: 手順 4、 3の画像 1 Alienware M17-R1 Screen Lock Assembly Replacement: 手順 4、 3の画像 2 Alienware M17-R1 Screen Lock Assembly Replacement: 手順 4、 3の画像 3
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
    FixBotに聞いてみる
  5. Alienware M17-R1 Screen Lock Assembly Replacement: 手順 5、 2の画像 1 Alienware M17-R1 Screen Lock Assembly Replacement: 手順 5、 2の画像 2
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
    FixBotに聞いてみる
  6. Alienware M17-R1 Screen Lock Assembly Replacement: 手順 6、 2の画像 1 Alienware M17-R1 Screen Lock Assembly Replacement: 手順 6、 2の画像 2
    • If the spring is defective, slide it off the end of the assembly and replace it.
    FixBotに聞いてみる
終わりに
作成者
2人の作成者と共同で作成されました。
William Davis
メンバー登録日: 10/09/18
323 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Sam Houston State, Team S15-G2, Blackburne Fall 2018人のメンバー
SHSU-BLACKBURNE-F18S15G2
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 46
今までの合計 666
