メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware AW610M Scroll Wheel Replacement
必要な工具と部品
    1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 1 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 2 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 3
      • Turn your mouse over with the scroll wheel facing down.
      • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
      • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
      FixBotに聞いてみる
      コメントを追加
    2. Alienware AW610M Scroll Wheel Replacement: 手順 2、 2の画像 1 Alienware AW610M Scroll Wheel Replacement: 手順 2、 2の画像 2
      • Turn your blowdryer on a low heat setting.
      • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
      • Turn off your blowdryer, unplug the device, and set it aside to cool down.
      • Carefully peel off the stickers, and set aside as well.
      FixBotに聞いてみる
      コメントを追加
    3. Alienware AW610M Scroll Wheel Replacement: 手順 3、 3の画像 1 Alienware AW610M Scroll Wheel Replacement: 手順 3、 3の画像 2 Alienware AW610M Scroll Wheel Replacement: 手順 3、 3の画像 3
      • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
      FixBotに聞いてみる
      コメントを追加
    4. Alienware AW610M Scroll Wheel Replacement: 手順 4、 1の画像 1
      • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
      • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
      FixBotに聞いてみる
      コメントを追加
    5. Alienware AW610M Scroll Wheel Replacement: 手順 5、 3の画像 1 Alienware AW610M Scroll Wheel Replacement: 手順 5、 3の画像 2 Alienware AW610M Scroll Wheel Replacement: 手順 5、 3の画像 3
      • Disconnect any wire connections away from the mouse's circuit board.
      • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
      • Locate the scroll wheel placed in the gap of the mouse's backing.
      • My scroll wheel was crooked, most likely causing my issue.
      • Gently lift the scroll wheel mechanism out of the mouse's backing.
      FixBotに聞いてみる
      コメントを追加
    6. Alienware AW610M Scroll Wheel Replacement: 手順 6、 3の画像 1 Alienware AW610M Scroll Wheel Replacement: 手順 6、 3の画像 2 Alienware AW610M Scroll Wheel Replacement: 手順 6、 3の画像 3
      • Disconnect the scroll wheel sensor from the mouse backing.
      • Remove the old wheel from the plastic casing, and set it aside.
      • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
      FixBotに聞いてみる
      コメントを追加
    7. Alienware AW610M Scroll Wheel Replacement: 手順 7、 3の画像 1 Alienware AW610M Scroll Wheel Replacement: 手順 7、 3の画像 2 Alienware AW610M Scroll Wheel Replacement: 手順 7、 3の画像 3
      • Dip a cotton swab into hydrogen-peroxide.
      • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
      • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
      • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Rana Ashour
メンバー登録日: 04/04/23
249 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 2-71, Briggs Spring 2023 CSU Los Angeles, Team 2-71, Briggs Spring 2023人のメンバー
CSULA-BRIGGS-S23S2G71
1 メンバー
3のガイドは作成済み
3件のガイドコメント
Note: the tan part connected to the ribbon cable IS A RECEPTACLE, THE RIBBON CABLE ITSELF IS THE PART THAT PULLS OUT. I accidentally pulled off my connector, lost a connector pin when attempting to put it back on, mouse still seems to work though.
Nathan - 返信 共有
Hello, I followed all the steps but I'm left with the two springs that I don't know where to put. I didn't see the two springs in your pictures.
Morar Razvan - 返信 共有
Same, did you find out where it went
ANDREW JOHNSON - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 84
過去 30 日: 388
今までの合計 16,408
