メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware 15 R2 Battery Replacement
必要な工具と部品
  1. Alienware 15 R2 Battery Replacement, RAM: 手順 1、 3の画像 1 Alienware 15 R2 Battery Replacement, RAM: 手順 1、 3の画像 2 Alienware 15 R2 Battery Replacement, RAM: 手順 1、 3の画像 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
    FixBotに聞いてみる
    コメントを追加
  2. Alienware 15 R2 Battery Replacement: 手順 2、 2の画像 1 Alienware 15 R2 Battery Replacement: 手順 2、 2の画像 2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
    FixBotに聞いてみる
    コメントを追加
  3. Alienware 15 R2 Battery Replacement: 手順 3、 2の画像 1 Alienware 15 R2 Battery Replacement: 手順 3、 2の画像 2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
    FixBotに聞いてみる
    コメントを追加
  4. Alienware 15 R2 Battery Replacement, Battery: 手順 4、 2の画像 1 Alienware 15 R2 Battery Replacement, Battery: 手順 4、 2の画像 2
    • Using a Phillips #0 remove the small 1X 3mm screw behind where the RAM used to be.
    • If you installed additional SSD's, you will need to remove those as well.
    FixBotに聞いてみる
    コメントを追加
  5. Alienware 15 R2 Battery Replacement: 手順 5、 1の画像 1
    • Remove all screws from the back casing. (4X 18mm, 4X 10mm, 6X 6mm)
    • Press your finger in the hole next to the hard drive to lift the key board. You may need an iFixit opening tool and work your way around the edges of the keyboard to get it fully lifted.
    • Move slowly as the power cable at the front of the keyboard is still attached to the motherboard as well as the ribbon cables.
    FixBotに聞いてみる
    コメントを追加
  6. Alienware 15 R2 Battery Replacement: 手順 6、 1の画像 1
    • Remove the ribbon cables on the bottom of the laptop to gain more room in order to lift the keyboard up and out of the way.
    • There is a power cable at the front of the keyboard that you can either remove to lift the keyboard out of the way entirely or keep it attached and rest the keyboard against the monitor face.
    FixBotに聞いてみる
    コメントを追加
  7. Alienware 15 R2 Battery Replacement: 手順 7、 1の画像 1
    • Disconnect and move aside the left and right wires.
    FixBotに聞いてみる
    コメントを追加
  8. Alienware 15 R2 Battery Replacement: 手順 8、 1の画像 1
    • Using a Phillips #0 remove the screws holding the battery in. (3X 6mm)
    FixBotに聞いてみる
    コメントを追加
  9. Alienware 15 R2 Battery Replacement: 手順 9、 1の画像 1
    • Remove the red, white, blue, and black colored speaker wires connected to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  10. Alienware 15 R2 Battery Replacement: 手順 10、 1の画像 1
    • Lift the battery from the front edge and remove.
    • There are two tabs at the front of the battery on each side that you need to slightly pry open in order to get the battery out. You can pull the speakers out in order to see the tabs better.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Nathaniel Evans
メンバー登録日: 09/18/19
451 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team S1-G2, Virtue Fall 2019 Western Carolina University, Team S1-G2, Virtue Fall 2019人のメンバー
WCU-VIRTUE-F19S1G2
4 メンバー
7のガイドは作成済み
3件のガイドコメント
Honestly made an account to comment on this repair guide, this is extremely incomplete. I’d go as far as saying you’re likely to damage the product by relying solely on this guide, I would turn to a breakdown on YouTube instead. I’m not sure if this is listed under the correct product.
mdumtshali - 返信 共有
The guide is good for someone who has already done repair work on laptops, but it may be difficult to understand for someone who does not have a lot of experience.
Bryan De Gracia - 返信 共有
Made a few modifications like removing the keyboard (and the steps required, this made it so much easier), there were a couple of screws not mentioned for removal, as well as paying attention to the tabs in front of the battery in order to remove it smoothly. Overall, I glad it was available, it at least got me off to a great start. Thanks
Dexter Dionisio - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 43
過去 30 日: 164
今までの合計 14,781
