メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alcatel OneTouch Evolve Sim Card Replacement
必要な工具と部品
    1. Alcatel OneTouch Evolve Sim Card Replacement, Locate the access tab: 手順 1、 1の画像 1
      • This will be an opening with enough space to insert the flat head of the plastic opening tool.
      • It will be located on the bottom right of the phone
      FixBotに聞いてみる
      コメントを追加
    2. Alcatel OneTouch Evolve Sim Card Replacement, Place the flat head end of the pry tool into the tab: 手順 2、 3の画像 1 Alcatel OneTouch Evolve Sim Card Replacement, Place the flat head end of the pry tool into the tab: 手順 2、 3の画像 2 Alcatel OneTouch Evolve Sim Card Replacement, Place the flat head end of the pry tool into the tab: 手順 2、 3の画像 3
      • Rotate the pry tool 90 degrees until the panel lifts up.
      • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
      FixBotに聞いてみる
      コメントを追加
    1. Alcatel OneTouch Evolve Sim Card Replacement, Identify the Battery: 手順 3、 1の画像 1
      • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
      FixBotに聞いてみる
      コメントを追加
    2. Alcatel OneTouch Evolve Sim Card Replacement, Removing the battery: 手順 4、 2の画像 1 Alcatel OneTouch Evolve Sim Card Replacement, Removing the battery: 手順 4、 2の画像 2
      • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
      FixBotに聞いてみる
      コメントを追加
    1. Alcatel OneTouch Evolve Sim Card Replacement, Locate Screws Holding the Secondary Panel in Place: 手順 5、 1の画像 1
      • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
      FixBotに聞いてみる
      コメントを追加
    2. Alcatel OneTouch Evolve Sim Card Replacement, Remove Screws: 手順 6、 1の画像 1
      この手順で使用する道具:
      • Unscrew each screw, counter-clockwise (left), until each one has been removed.
      • If necessary, use tweezers to fully remove the screws from the device.
      • Remove battery before lifting off the panel.
      FixBotに聞いてみる
      コメントを追加
    3. Alcatel OneTouch Evolve Sim Card Replacement, Prying the Panel Off: 手順 7、 3の画像 1 Alcatel OneTouch Evolve Sim Card Replacement, Prying the Panel Off: 手順 7、 3の画像 2 Alcatel OneTouch Evolve Sim Card Replacement, Prying the Panel Off: 手順 7、 3の画像 3
      • Access the small pry tool in the tool kit
      • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
      • Rotate the pry tool 90 degrees until part of the panel lifts up
      • All areas need to be fully risen off before the panel can be removed.
      • Do not use the opening tool to pry open the device near the power button or near the volume button.
      FixBotに聞いてみる
      コメントを追加
    1. Alcatel OneTouch Evolve Sim Card Replacement, Locate Sim Card: 手順 8、 2の画像 1 Alcatel OneTouch Evolve Sim Card Replacement, Locate Sim Card: 手順 8、 2の画像 2
      • The SIM card is located below the battery in an easy to access location.
      • If there is currently no SIM card in the phone, it will be a blank area
      FixBotに聞いてみる
      コメントを追加
    2. Alcatel OneTouch Evolve Sim Card Replacement, Remove the SIM Card: 手順 9、 2の画像 1 Alcatel OneTouch Evolve Sim Card Replacement, Remove the SIM Card: 手順 9、 2の画像 2
      この手順で使用する道具:
      • The SIM card is encased in a housing unit. In order to remove it, push left as written on the metal housing cover and it will snap loose and be able to be risen.
      • Place finger on metal housing. While applying a downward force, push the finger in the direction towards the edge of the phone. An arrow also indicated this direction
      • This housing case top will be on a hinge system. Put this top in the upper position and remove card with finger tips, or if necessary, tweezers.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brendan Egan
メンバー登録日: 10/28/14
2,491 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G5
3 メンバー
48のガイドは作成済み
4件のガイドコメント
Easy to follow. Great help. Thank you!
cathyf48 - 返信 共有
Which simcard can I use for Alcatel one touch Wi-Fi in kenya?
james wangwa - 返信 共有
Which sim card can I use for Alcatel one touch Wi-Fi in kenya?
Thank you very much. I thought it has an inbuilt SIM at first. Some of this Model have six screw.
JAMES OBIA - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 143
今までの合計 59,520
