はじめに
If cleaning the camera lens and adjusting the camera settings does not fix the quality of pictures, you may need to replace the camera inside the Alcatel One Touch Pop 7. This guide will show you how to do so easily.
必要な工具と部品
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
この手順で使用する道具:Tweezers$4.99
The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
