はじめに
HDD hard drive access and BIOS stack
必要な工具と部品
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
For reassembly, follow the instructions above in the reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Israelさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
