メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AT-LP120-USB Start/Stop Button Replacement
必要な工具と部品
    1. AT-LP120-USB Start/Stop Button Replacement, Preparation: 手順 1、 1の画像 1
      • Disconnect your turntable from power and audio.
      • Move the turntable to a clear flat surface.
      FixBotに聞いてみる
      コメントを追加
    2. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Necessary Accessories: 手順 2、 1の画像 1
      • In this step, we are removing the necessary accessories to mitigate the possibility of damage in the upcoming steps.
      • Engage the tone arm clamp
      • Remove 45 adaptor.
      • Remove slipmat.
      • Remove platter by using the two circular holes and pulling vertically from the top of the turntable.
      • Remove the counterweight by unscrewing the rear clockwise.
      FixBotに聞いてみる
      コメントを追加
    3. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Tie Down Tone Arm: 手順 3、 1の画像 1
      • This step is an extra precaution in case the tone arm clamp becomes loose during handling.
      • Tie down the tone arm using a twist tie/zip tie.
      • The next step involves flipping the turntable onto the the dust cover. At this time it would be best to find a soft surface (ie. cloth, foam, etc.) to place it on to mitigate damage to the dust cover.
      FixBotに聞いてみる
      コメントを追加
    4. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Screws: 手順 4、 1の画像 1
      • Place on soft surface (ie. cloth, foam, etc) to mitigate risk of damaging the dust cover.
      • Carefully flip the turntable onto the dust cover.
      • Remove 8 screws.
      • Each screw is accompanied by one brass bushing. These bushings might come out still attached to the screws, or will stay inside the turntable.
      FixBotに聞いてみる
      コメントを追加
    5. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Bottom Cover: 手順 5、 3の画像 1 AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Bottom Cover: 手順 5、 3の画像 2 AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Bottom Cover: 手順 5、 3の画像 3
      • Spin the turntable so that the rear is facing you.
      • Lift off the bottom cover.
      • Depending on manufacturer date, you may need to tilt the bottom cover to pull it away from the ports/switches.
      • Remove the hinges if they do not come out of the dust cover when lifting.
      • As you pull the bottom cover off, the RCA cables will be removed through this hole.
      FixBotに聞いてみる
      コメントを追加
    6. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Locate The Button: 手順 6、 3の画像 1 AT-LP120-USB Start/Stop Button Replacement, Disassembly: Locate The Button: 手順 6、 3の画像 2 AT-LP120-USB Start/Stop Button Replacement, Disassembly: Locate The Button: 手順 6、 3の画像 3
      • Spin the turntable back around such that the front is closest to you.
      • Locate and collect the 8 brass bushings if they did not come out with the screws.
      • Slide the bushings to the head of each screw and set aside for later.
      • The button that is being removed can be located here.
      FixBotに聞いてみる
      コメントを追加
    7. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing Clamp and Washer: 手順 7、 3の画像 1 AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing Clamp and Washer: 手順 7、 3の画像 2 AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing Clamp and Washer: 手順 7、 3の画像 3
      この手順で使用する道具:
      • Adjust the turntable on top of the dust cover such that the button is protruding from the PCB.
      • Use a pair of tweezers or needle-nose pliers to remove the silver clamp.
      • The clamp requires a bit of force to be pulled off from the post.
      • Remove the black felt washer from the post.
      • Do not dispose of any pieces that come off of the button as these will be used on the replacement button.
      FixBotに聞いてみる
      コメントを追加
    8. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing The Button: 手順 8、 3の画像 1 AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing The Button: 手順 8、 3の画像 2 AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing The Button: 手順 8、 3の画像 3
      • The button is now loose and is able to be removed.
      • Adjust the turntable so the dust cover is no longer holding the button up.
      • Remove the button and spring if it did not fall from adjusting the turntable.
      • Remove the spring and black felt washer from the button shaft.
      • If the spring and/or black felt washer are not attached to the button upon removal they are likely stuck near where the button was removed from.
      FixBotに聞いてみる
      コメントを追加
    9. AT-LP120-USB Start/Stop Button Replacement, Replacement: Configuring The New Button: 手順 9、 1の画像 1
      • Locate your replacement button and place it such that the black plastic post is closest to you.
      • Keeping the button in this orientation for the remainder of the repair will ensure the correct orientation upon completion.
      • Slide the black felt washer down to the base of the shaft.
      • Position the spring around the shaft in-between the small plastic posts.
      FixBotに聞いてみる
      コメントを追加
    10. AT-LP120-USB Start/Stop Button Replacement, Replacement: Inserting And Securing The Button: 手順 10、 2の画像 1 AT-LP120-USB Start/Stop Button Replacement, Replacement: Inserting And Securing The Button: 手順 10、 2の画像 2
      • Insert the button back into the base of the turntable with the small highlighted post from Step 9 closest to you.
      • Slide the black felt washer onto the shaft of the new button.
      • Press the clamp back into the grooved portion of the shaft.
      • Attaching the clamp will require some force. The technicians normally use the flat handle side of their tweezers to push the clamp into place.
      FixBotに聞いてみる
      コメントを追加
    11. AT-LP120-USB Start/Stop Button Replacement, Reassembly: Placing Bottom Cover: 手順 11、 3の画像 1 AT-LP120-USB Start/Stop Button Replacement, Reassembly: Placing Bottom Cover: 手順 11、 3の画像 2 AT-LP120-USB Start/Stop Button Replacement, Reassembly: Placing Bottom Cover: 手順 11、 3の画像 3
      • Spin the turntable back around such that the rear is facing you.
      • Place the hinges back into the dust cover.
      • Press this part of the hinge so the hinge is in a vertical position.
      • Locate the bottom cover, and route the RCA cables com from the turntable through this hole.
      • Place the bottom cover onto the turntable such that the dust cover hinges are inserted into their respective brackets, and all ports are visible.
      • Depending on manufacturer date, you may need to tilt the bottom cover and insert the ports/switches before re-attaching the hinges and dust cover.
      FixBotに聞いてみる
      コメントを追加
    12. AT-LP120-USB Start/Stop Button Replacement, Reassembly: Securing Bottom Cover: 手順 12、 1の画像 1
      • Insert the 8 screws with the brass bushings attached into the bottom cover.
      • Brass bushing placement on the screw is shown in Step 6
      • The turntable is now reassembled.
      FixBotに聞いてみる
      コメントを追加
終わりに
If the motor continues to have no reaction to pressing the start/stop button after reconnecting the turntable to power and reattaching the platter, the issue is likely caused by a faulty motor.
For further technical assistance, please contact service@atus.com or one of the technicians at (330)686-2600 ext.5004
~Monday-Friday 8:00am to 5:00pm~
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Anthony @ ATUS
メンバー登録日: 02/28/19
1,216 ポイント
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 78
今までの合計 1,751
