メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS Eee PC 1018P Hard Drive Replacement
必要な工具と部品
  1. ASUS Eee PC 1018P Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    FixBotに聞いてみる
    コメントを追加
  2. ASUS Eee PC 1018P Hard Drive Replacement: 手順 2、 2の画像 1 ASUS Eee PC 1018P Hard Drive Replacement: 手順 2、 2の画像 2
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    FixBotに聞いてみる
    コメントを追加
  3. ASUS Eee PC 1018P Hard Drive Replacement: 手順 3、 3の画像 1 ASUS Eee PC 1018P Hard Drive Replacement: 手順 3、 3の画像 2 ASUS Eee PC 1018P Hard Drive Replacement: 手順 3、 3の画像 3
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
    FixBotに聞いてみる
    コメントを追加
  4. ASUS Eee PC 1018P Hard Drive Replacement, Keyboard: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Remove the screws securing the bottom case to the keyboard.
    • Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
    • Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
    • With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
    FixBotに聞いてみる
    コメントを追加
  5. ASUS Eee PC 1018P Hard Drive Replacement: 手順 5、 2の画像 1 ASUS Eee PC 1018P Hard Drive Replacement: 手順 5、 2の画像 2
    • Pry the cover free from the chasis by inserting the plastic opening tool between the keyboard and the lower body of the Asus Eee PC 1018P.
    • Prying a keyboard from a laptop requires a lot of force, but the keyboard also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    FixBotに聞いてみる
    コメントを追加
  6. ASUS Eee PC 1018P Hard Drive Replacement: 手順 6、 1の画像 1
    • Lift the outside edge of the keyboard upward and inward towards the screen. (See warning below.)
    • Take care not to lift the keyboard too high from the motherboard, as this may sever the ribbon cables that are still attached.
    FixBotに聞いてみる
    コメントを追加
  7. ASUS Eee PC 1018P Hard Drive Replacement: 手順 7、 3の画像 1 ASUS Eee PC 1018P Hard Drive Replacement: 手順 7、 3の画像 2 ASUS Eee PC 1018P Hard Drive Replacement: 手順 7、 3の画像 3
    • Remove the black ribbon cable from the motherboard.
    • Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
    • Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
    • Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
    FixBotに聞いてみる
    コメントを追加
  8. ASUS Eee PC 1018P Hard Drive Replacement: 手順 8、 3の画像 1 ASUS Eee PC 1018P Hard Drive Replacement: 手順 8、 3の画像 2 ASUS Eee PC 1018P Hard Drive Replacement: 手順 8、 3の画像 3
    • Remove the white ribbon cable from the motherboard.
    • Insert the plastic opening tool under the small lip of the white ribbon connector, and pry upwards to pop the motherboard connector up.
    • Carefully remove the white ribbon cable by pulling it horizontally towards the touch pad.
    FixBotに聞いてみる
    コメントを追加
  9. ASUS Eee PC 1018P Hard Drive Replacement: 手順 9、 1の画像 1
    • The keyboard is now fully disconnected and can now be removed from the main body of the Asus Eee PC 1018P.
    FixBotに聞いてみる
    コメントを追加
  10. ASUS Eee PC 1018P Hard Drive Replacement, Hard Drive: 手順 10、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 4.52 mm screws securing the hard drive case to the laptop.
    FixBotに聞いてみる
    コメントを追加
  11. ASUS Eee PC 1018P Hard Drive Replacement: 手順 11、 1の画像 1
    • Carefully peel off the tape that secures the black cables to the hard drive.
    • Do not discard the tape.
    FixBotに聞いてみる
    コメントを追加
  12. ASUS Eee PC 1018P Hard Drive Replacement: 手順 12、 3の画像 1 ASUS Eee PC 1018P Hard Drive Replacement: 手順 12、 3の画像 2 ASUS Eee PC 1018P Hard Drive Replacement: 手順 12、 3の画像 3
    • Lift the left side of the hard drive slightly. Gently pull the hard drive to the left in order to free it from the pin connection on the right side.
    • Continue pulling the hard drive out from the socket until it's free from the rest of the laptop.
    • Removing the hard drive at too great or too small an angle can cause damage to both the hard drive and the connector to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  13. ASUS Eee PC 1018P Hard Drive Replacement: 手順 13、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the four 3.68 mm screws securing the hard drive case to the hard drive. There are two on each side of the hard drive case.
    FixBotに聞いてみる
    コメントを追加
  14. ASUS Eee PC 1018P Hard Drive Replacement: 手順 14、 1の画像 1
    • The hard drive is now fully removed and ready to be replaced.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Daniel Rodman
メンバー登録日: 01/20/12
309 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G13
4 メンバー
11のガイドは作成済み
3件のガイドコメント
It helps when you start to pry open the cover at the SD card slot instead of some random point as there is some space to go between. Don't insert your tool too deeply though or you you might damage the frame that sits further in.
Andre - 返信 共有
Short, clear, accurate. Thank you! awesome student :)
Alex - 返信 共有
Any advice on replacing with a SSD drive?
SATA II 3GBs
Would a 6gbs drive be a waste? or even work?
same question for SATA III
terrymcp63 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 37
今までの合計 9,686
