メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS Eee PC 1018P Fan Replacement
必要な工具と部品
  1. ASUS Eee PC 1018P Fan Replacement, Battery: 手順 1、 1の画像 1
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    FixBotに聞いてみる
    コメントを追加
  2. ASUS Eee PC 1018P Fan Replacement: 手順 2、 2の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 2、 2の画像 2
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    FixBotに聞いてみる
    コメントを追加
  3. ASUS Eee PC 1018P Fan Replacement: 手順 3、 3の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 3、 3の画像 2 ASUS Eee PC 1018P Fan Replacement: 手順 3、 3の画像 3
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
    FixBotに聞いてみる
    コメントを追加
  4. ASUS Eee PC 1018P Fan Replacement, Keyboard: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Remove the screws securing the bottom case to the keyboard.
    • Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
    • Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
    • With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
    FixBotに聞いてみる
    コメントを追加
  5. ASUS Eee PC 1018P Fan Replacement: 手順 5、 2の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 5、 2の画像 2
    • Pry the cover free from the chasis by inserting the plastic opening tool between the keyboard and the lower body of the Asus Eee PC 1018P.
    • Prying a keyboard from a laptop requires a lot of force, but the keyboard also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    FixBotに聞いてみる
    コメントを追加
  6. ASUS Eee PC 1018P Fan Replacement: 手順 6、 1の画像 1
    • Lift the outside edge of the keyboard upward and inward towards the screen. (See warning below.)
    • Take care not to lift the keyboard too high from the motherboard, as this may sever the ribbon cables that are still attached.
    FixBotに聞いてみる
    コメントを追加
  7. ASUS Eee PC 1018P Fan Replacement: 手順 7、 3の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 7、 3の画像 2 ASUS Eee PC 1018P Fan Replacement: 手順 7、 3の画像 3
    • Remove the black ribbon cable from the motherboard.
    • Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
    • Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
    • Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
    FixBotに聞いてみる
    コメントを追加
  8. ASUS Eee PC 1018P Fan Replacement: 手順 8、 3の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 8、 3の画像 2 ASUS Eee PC 1018P Fan Replacement: 手順 8、 3の画像 3
    • Remove the white ribbon cable from the motherboard.
    • Insert the plastic opening tool under the small lip of the white ribbon connector, and pry upwards to pop the motherboard connector up.
    • Carefully remove the white ribbon cable by pulling it horizontally towards the touch pad.
    FixBotに聞いてみる
    コメントを追加
  9. ASUS Eee PC 1018P Fan Replacement: 手順 9、 1の画像 1
    • The keyboard is now fully disconnected and can now be removed from the main body of the Asus Eee PC 1018P.
    FixBotに聞いてみる
    コメントを追加
  10. ASUS Eee PC 1018P Fan Replacement, Fan: 手順 10、 2の画像 1 ASUS Eee PC 1018P Fan Replacement, Fan: 手順 10、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the two 3.76 mm screws securing the fan/heat sink assembly to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  11. ASUS Eee PC 1018P Fan Replacement: 手順 11、 2の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 11、 2の画像 2
    • An additional 3.76 mm Phillips screw is hidden under the seal that reads, "WARRANTY VOID IF SEAL BROKEN OR REMOVED." Remove this sticker to access the screw.
    • Use a Phillips #0 screwdriver to remove the screw.
    FixBotに聞いてみる
    コメントを追加
  12. ASUS Eee PC 1018P Fan Replacement: 手順 12、 1の画像 1
    • Using the spudger, gently push at the top and bottom ridges of this wire bus to disconnect it from the socket.
    FixBotに聞いてみる
    コメントを追加
  13. ASUS Eee PC 1018P Fan Replacement: 手順 13、 1の画像 1
    • Slide the spudger under the righthand edge of the copper heat sink in order to disconnect it from the thermal pad below.
    FixBotに聞いてみる
    コメントを追加
  14. ASUS Eee PC 1018P Fan Replacement: 手順 14、 3の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 14、 3の画像 2 ASUS Eee PC 1018P Fan Replacement: 手順 14、 3の画像 3
    • Peel the foam adhesive pad off from the top of the copper plate, as well as the tape located beneath that.
    FixBotに聞いてみる
    コメントを追加
  15. ASUS Eee PC 1018P Fan Replacement: 手順 15、 2の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 15、 2の画像 2
    • Gently remove the fan.
    FixBotに聞いてみる
    コメントを追加
  16. ASUS Eee PC 1018P Fan Replacement: 手順 16、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 2.35 mm screws securing the fan to the copper plate.
    FixBotに聞いてみる
    コメントを追加
  17. ASUS Eee PC 1018P Fan Replacement: 手順 17、 3の画像 1 ASUS Eee PC 1018P Fan Replacement: 手順 17、 3の画像 2 ASUS Eee PC 1018P Fan Replacement: 手順 17、 3の画像 3
    • Gripping the fan with one hand and the copper plate with the other, gently pull them apart.
    • The fan is now fully removed.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
Anthony Valdez
メンバー登録日: 01/20/12
60 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G13
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 29
今までの合計 7,037
