はじめに
このガイドを参照して、乾燥したマーキングペンを元の状態に戻します。
ご注意: ペンの乾き具合によっては、この作業を数回繰り返す必要があります。
マーキングペンの先端が完全に浸る程度まで、コップにイソプロピルアルコールを注ぎます。
ペンの先端を下にしてカップ内に配置します。
アルコールがペン先にしみ込むまで15分ほど待ちます。
この手順で使用する道具:FixMat$36.95
カップからペンを取り出し、ペン先に残ったアルコールを拭き取ります。
FixMatなどのマット上で、ペン先からアルコールが抜けるまでペンを何度も往復させます。
おめでとうございます!これでペンは以前のように使用できる状態に戻りました!
Brand new pen turned up dry and this fix didn't work.
Paul Nevin - 返信
My pen has been iffy for quite a while—not dried out, but writing poorly. One round each of isopropyl and water have got it working beautifully.
10 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
10 件のコメント
Unfortunately this did not help for me.
Apparently this pen that comes with the FixMat cannot be purchased, but is covered by the lifetime warranty. Send an email to support@ifixit.com to get replacement pens.
P.S. It's called the iFixit Marking Pen
Same for me, I repeated the guide 3 times, it didn't helped, I wish I could just open it and use a replacement, it's cheap to buy but I feel bad of throwing everything, and also the pen dries super fast I think I need to buy another one and just glue some metal plate to use with the I fix it magnetic mat
See my reply above
Seems to have done the trick, thanks. It was a brand new pen and must've dried out on the shelf.
Further tip:
If you wrap a pair of tweezers around it, and lay the tweezers across the top of a glass, it's pretty easy to stand the pen perfectly upright, even if it's a short+wide glass.
Update: the fix only lasted a few days. It's dried out again. The cap may have been slightly loose though (friction fit, not clicked into position).
Sam L. -
I received a replacement from ifixit wich is great but I ended up having the dame problem and this guide also using comments suggestions didn't work, I'm not going to request more replacement because I think it's a product fault, and I don't want to generate more waste If they make a new oen and sell separate I'll be happy to purchase
