メインコンテンツにスキップ
この文書の最初のページのプレビュー
全文をご覧になるには、ログインしてください
4ページ · 29.59 kb · PDF
ログイン
REMOVAL
  1. REMOVE REAR WHEEL
Torque: 103 N·m (1.050 kgf·cm, 76 ft·lbf)
  1. DISCONNECT FLEXIBLE HOSE
  2. (a) Remove the union bolt and 2 gaskets from the caliper, then disconnect the flexible hose from the caliper.
Torque: 29 N·m (300 kgf·cm, 21 ft·lbf)
HINT:
At the time of installation, please refer to the following it Insert the flexible hose lock securely in the lock hole in the per.
  • (b) Use a container to catch the brake fluid as it drains o
  1. REMOVE CALIPER
  • (a) Remove the installation bolt.
Torque: 20 N·m (200 kgf·cm, 14 ft·lbf)
  • (b) Remove the caliper from the torque plate.
  1. REMOVE 2 BRAKE PADS WITH 4 ANTI-SQUEAL SHIMS
  2. REMOVE 4 PAD SUPPORT PLATES
NOTICE:
At the time of installation, please refer to the following item There should be no oil or grease adhering to the friction surfaces of the pads or disc.
  1. REMOVE MAIN PIN
Loosen the main pin installation bolt and remove the main pin.
Torque: 26 N·m (270 kgf·cm, 20 ft·lbf)
BR0B3-03
DISASSEMBLY
  1. REMOVE SLIDING BUSHING
  2. REMOVE 2 DUST BOOTS
  3. REMOVE MAIN PIN BOOT
NOTICE: Ensure that the boots are secured firmly to the bushing and caliper grooves.
  1. REMOVE CYLINDER BOOT SET RING AND BOOT (See step 1 on page BR-27 )
  2. REMOVE PISTON (See step 2 on page BR-27 )
  3. REMOVE PISTON SEAL (See step 3 on page BR-27 )
BR0B4-02
INSPECTION
  1. MEASURE PAD LINING THICKNESS
(See step 1 on page BR-28 )
Standard thickness:
10.0 mm (0.394 in.)
Minimum thickness: 1.0 mm (0.039 in.)
  1. MEASURE DISC THICKNESS
(See step 2 on page BR-28 )
Standard thickness: 10.0 mm (0.394 in.)
Minimum thickness: 9.0 mm (0.354 in.)
  1. MEASURE DISC RUNOUT
(See step 3 on page BR-28 )
Maximum disc runout: 0.15 mm (0.0059 in.)
If the disc's runout is maximum value or greater, check the bear ing play in the axial direction and check the axle hub runo (See page SA-52 ). If the bearing play and axle hub runout are not abnormal, adjust the disc runout or grind it on a 'On-Car brake lathe.
  1. IF NECESSARY, ADJUST DISC RUNOUT
  2. (a) Remove the 2 bolts and torque plate.
  3. (b) Remove the hub nuts and the disc. Reinstall the disc in the position turned 1/5 from its original position on hub. Install and torque the hub nuts.
Remeasure the disc runout. Make a note of the runout and the disc's position on the hub.
Torque: 103 N·m (1,050 kgf·cm, 76 ft·lbf)
  • (c) Repeat (b) until the disc has been installed on the 3 r maining hub positions.
  • (d) If the minimum runout recorded in (b) and (c) is less th 0.15 mm (0.0059 in.), install the disc in that position.
  • (e) If the minimum runout recorded in (b) and (c) is greate than 0.15 mm (0.0059 in.), replace the disc and repeat step 3.
  • (f) Install the torque plate and torque the mounting bolts.
Torque: 47 N·m (475 kgf·cm, 34 ft·lbf)
BR0B5-02
REASSEMBLY
Reassembly is in the reverse order of disassembly (See page BR-41 ). NOTICE:
Apply lithium soap base glycol grease to the parts indicated by the arrows (See page BR-24 ).
BR0B6-01
