メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2399回答 すべてを表示
My iPhone 4 got soaked, dried out, but will not power up
My iPhone 4 got completely soaked. It tried booting up when it was drying out. I didn't know the trick to forcing it to turn off. It finally turned off itself (scary). I dried it out for a couple of days (with sunlight and rice). It would not boot up. It also does not even recognize with it's plugged into the computer to charge. I changed out the battery, but it still does nothing. What should be my next step?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 20
6 件のコメント
How did you take the batery out
さんによる
You can remove the battery with this guide: iPhone 4のバッテリーの交換
さんによる
I also have this problem and I have an Android LG!! Please help!!
さんによる
I have a ipod 6 i tried the rice trick and another what do i do!!???
さんによる
i dropped my phone in the toilet, but i noticed it right away so i grabbed it ASAP, it was working for a little but then it randomly completely turned off, i put it in rice, but i was checking it and the apple screen kept turning on but it kept turning off, and i dont know what to do...
さんによる
1以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
Hey Shellie,
So first, a little background info on water damage. When liquid gets inside a device, it does not damage it. The problems occur when power runs through the logic board. If any of the water bridges some of the traces on the logic board, it may cause the logic board to shirt circuit, effectively frying the entire device.
Since your device was running while soaked, it sounds like the logic board was probably fried, especially since it turned off on its own and does not respond to being plugged in. Unfortunately, this means that in order to fix your device, you will probably need to replace the logic board. Before doing that, though, I would recommend just taking it in to an Apple store and seeing if they might replace it. They replaced a MacBook Pro logic board for me one time after I spilled liquid on it and effectively fried it.
Hope this helps! Good luck!
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
How much did they charge you?
さんによる
"shirt circuit" Ima start saying that
さんによる
コメントを追加
I bought a waterdamaged iphone off of ebay that would not turn on or be charge/connect to itunes. I took the phone apart, and followed this youtube video.
http://www.youtube.com/watch?v=zLoFdqNf3...
I also replaced the battery which is like $6 or less on amazon or ebay.
After doing this, the phone turned on, everything functioned perfect - camera, touch screen, vibrate, speaker, etc - except my dock connector. Basically my phone operates perfect, but the dock connector for charging/connecting doesn't work, even after I replaced the dock connector. I've heard others having luck and everything including the dock connector works after doing this. Still working on this problem haha.
Anyway good luck!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I know but they're talking about a IPhone. You can't take apart an IPhone.y iphone 6 got water damage and I'm looking for some answers. They're talkingg about an IPhone and you CANNOT take that apart.
さんによる
@magconlover88 Well you can but it's hard because it's so delicate.
さんによる
コメントを追加
Shellie, I am an eternal optimist:-). I would suggest that before you get all frustrated and go and buy the most expensive part, see if you can diagnose the things that are having issues first. Number one thing is to not trying to start your phone until it is properly cleaned. The drying via sunlight and Rice will not clean it. It will not prevent corrosion. Start by using this guide for the clean up. It is written for a 3G but all the steps are still valid for your phone. To work on your phone, usethese guides. Once you have it properly cleaned, definitely replace the battery. After that, reassemble your phone and re-evaluate for further damage. Since your phone is not charger and not recognized, you may have to get a dock connector as well, but stop there until you know for sure. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I want to open my iphone
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@oegegomoen38934 when you say open it, do you mean to disassemble it? Use these guides iPhone 4
さんによる
コメントを追加
回答を追加する
Shellie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 112,130
