Trackpad replacement without keyboard replacement
Can the trackpad be replaced without replacing the keyboard? I have a broken trackpad and can't seem to find a part number for it. My mac is a MacBook Unibody Model A1278.
Thank You
Yes it can! Your part number is 922-9014. You will, however, need a tri-wing screw driver to replace it. Plugging that part number into Google will lead you to the part.
Good luck!
このアンサーは役に立ちましたか?
Thank You for responding my post. I found the part using the part number you provided.
このアンサーは役に立ちましたか?
Great! I'm glad you found what you needed!
I have a late 2008 model Macbook 5,1 aluminum case version. Is this a A-1278? I have a defective trackpad on the unit and need a replacement. Is the part number 922-9014 correct? Thanks, Knut Holzer
このアンサーは役に立ちましたか?
Have the same question as above: also have a late 2008 model MacBook 5,1.
このアンサーは役に立ちましたか?
Same here. Would love to know.
このアンサーは役に立ちましたか?
These old questions rarely get looked at. Asking a new question brings better results and new things may have been learned in the last year and half.
http://www.everymac.com/ultimate-mac-loo...
Yes, they are all the same machine.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 10,747
