メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
コードネームA34と呼ばれる第6世代のMaximaは、米国、カナダ、メキシコのみで販売されました。2003年の北米国際オートショーにて、2004年モデルとして発表されました。
Driver's door key lock
The key will not manually unlock the driver's door. The mechanism appears to be frozen. How do I access the mechanism to try and free it up?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
If frozen from subfreezing temps, you may be able to defrost the lock cylinder with lock lube or hand sanitizer. Warming the key blade can help melt frozen water while lock lube/sanitizer will help lube and free the lock cylinder.
If not frozen from subfreezing temps and seized from years of non use, you may have to remove the lock cylinder from inside the door panel. You may have to decide whether to attempt removal, cleaning and lubing the lock mechanism and see if lube frees up corrosion for flushing with solvent like throttle cleaner followed by applying lock lube for long term reliability.
さんによる 共有
コメントを追加
1 件の回答
I asked FixBot (Ai) for door lock removal with its reply in italics. Beware of Ai mistakes.
For a frozen lock, water freezing can melt with a warmed key along with lock lube or hand sanitizer. If seized and not frozen from freezing temps, removing the lock may be necessary for cleaning, lubing or replacement.
Door Lock Cylinder Service And Repair — 2006 Nissan Datsun Maxima V6 3.5L (VQ35DE) Service Manual ~ LEMON Manuals
"removing door lock cylinder"
To remove the driver's door lock cylinder on your 2004–2008 Nissan Maxima, you will need to access the inside of the door panel and release it from the exterior handle assembly.
Here is what the procedure involves:
  1. Remove the interior door panel: Disconnect the battery 1, pop off the screw cover behind the inside door handle, remove its retaining screw 1, remove the window switch trim and switches 1, and unclip the door finisher panel from its fasteners.
  2. Access the door jamb bolt: Peel back the protective water shield inside the door, locate the rubber grommet on the side edge (jamb) of the door, and remove it. Loosen the Torx retaining bolt hidden inside that hole (this secures the outside handle/lock assembly from the side) 2.
  3. Disconnect the linkage: Detach the key cylinder rod or cable clip linking the cylinder to the internal door latch mechanism 2.
  4. Remove the lock cylinder: From the outside of the door, pull the exterior handle outward, then pull the key cylinder assembly outward and toward the rear of the vehicle to slide it free from its housing or escutcheon (you may need to pop off a small retaining clip or pawl holding it in place) 2.
Let me know if you need help with a specific part of the trim removal or reassembly!
Sources:
1 Genuine Nissan Maxima Door Lock Cylinder
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Romaxco さん、ありがとうございました!
統計データ:
過去 24時間: 13
過去 7 日: 35
過去 30 日: 35
今までの合計 35
