Can you change the screen of a 3DS?
The right side portion of my top screen is black and has a small crack. How and where can I fix it?
alexia munguia, you can fix it by following this guide. If you want to get it fixed, you'd better Google for a service that is close to your geographic location. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Yes, I agree with Old Turkey, just follow that guide and use the tools you need. If you really are going to fix it yourself, here's a top screen replacement that you can buy: http://www.ebay.com/itm/Top-Upper-Replac...
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 7
今までの合計 9,900
5 件のコメント
it don't work
michael dowell15 さんによる
there thoughts are wroung!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
how can i fix my screen that has a crack in it
princessajasmine1 さんによる
the screen im talking about is the 3ds
theres aproblem with it ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
