How do I clean the machine's drain
Does this machine have a drain/filter assembly that could be cleaned; I have a dog that sheds.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There is a drain filter located at the bottom of the basket but it's not considered to be user removable.
You would have to remove the drain pump from the machine and check that there's no blockage in the hose connected to the input to the drain pump, in the drain pump itself or in the drain hose leading to the house drain pipe.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 24
過去 30 日: 38
今までの合計 38
