メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsungは2023年2月1日に開催されたイベント「Unpacked」で、Galaxy S23シリーズを発表しました。また、新しいノートPCシリーズであるGalaxy Book3およびGalaxy Book3 Proも同時に発表されました。
Broken battery pull tab; Safe ways to pry out battery?
​I tried replacing the battery using the iFixit kit (without isopropyl alcohol). Whilst trying to pull out the old battery, the blue pull tab snapped, and I’m a bit hesitant to use a prying tool.
​I’ve closed everything back up for now and will buy a bottle of isopropyl alcohol.
​Could I get some tips on prying out the battery safely without damaging it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @keralite
I find the best way to do this is to apply a line of Isopropyl Alcohol 99%+ along one side edge and the bottom edge of the battery, using an 18G blunt tip dispensing syringe,¹ allow the alcohol a few minutes to soften the adhesive and then gently, use a pry tool to lift the battery up a small bit.
Then apply some more alcohol under the slightly raised edge of the battery, wait for the adhesive to soften a bit and then pry the battery up further and so on until it is completely removed from the case.
Notes:
¹ Examples only. You could always ask your local pharmacist if they have anything suitable that you could use. Just explain what you want to do with it ;-)
Do not attempt to remove the battery all at once. Raise it a bit at a time.
Do not use a metal pry tool as you may easily puncture the battery. Old credit cards or guitar picks can work if you don't have a plastic spudger.
Remember to disconnect the battery cable from the systemboard before commencing the removal procedure and to dispose of the old battery responsibly at a hazardous waste collection point in your location.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Abhishek K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 65
今までの合計 146
