メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
Why does my fan run constantly at max speed after being replaced?
I recently replaced the fan in my macbook after the original fan had issues with the bearings. After reconnecting everything and turning the computer on the fan runs smoothly.
After using the computer for a couple hours I noticed the fan rpm never dipped below 6000 rpm. No processes were hogging the cpu (verified in Activity Monitor) and iStat displays temperature readings from all the sensors so I doubt I have an issue where the sensor became disconnected (current CPU temp is 113 F and fan speed is at 6000 rpm). I've also reset both SMC and PRAM to no avail.
Are there any steps I can take to make the new replacement fan behave normally?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Very odd
The only thing I can think of is did you blow out the dust in the heat sink grills and redo the thermo paste on the CPU and GPU? But, that assumes the systems temp probes are running high. Don't forget your HD and GPU temperature also effect the fans.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 535
