メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
Is backlit keyboard compatible with MacBook?!
Just wanted to see if i could install the backlit keyboard on my MacBook. Mine did not come with it and im kicking myself! are the connectors all there? Can i just buy the lights or do i need the entire keyboard asembly? Thanks!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hey guys, I just did it. For better results, though remove the optical drive. It is much easier.
And this is where I bought the backlight film - http://www.ebay.co.uk/itm/USED-APPLE-Mac...
さんによる
コメントを追加
19件の回答
ベストアンサー
You should be able to install the backlit keyboard with no problem. Here's the part: MacBook Unibody (A1278) Upper Case (Backlit)
Here's how to put it in: MacBook Unibody Model A1278 Upper Case Replacement
As far as I know, the whole top has to be replaced.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
That does not apply to the every mainly because it is for the aluminum macbook. And besides no one wants to spend 200 dollars just for a backlit keyboard considering that 2013 and below MacBooks are sub 200 dollars.
One more thing to consider, the website on how to replace it done by experts says it difficult to replace it. So this messes with the whole DIY vibe.
SO DON'T BUY ANYTHING FROM THE LINK PROVIDED BY MAYER PLEASE!
さんによる
@brykisher DID YOU LOOK AT THE DATE ON MY ANSWER? IT WAS EIGHT YEARS AGO! PRICES CHANGE IN EIGHT YEARS. Prices do not change on parts that are out of stock.
さんによる
Yeah exactly apple products were more expensive 8 years ago. Also, prices for parts fluctuate. i was referring to older macs because of the date.
さんによる
コメントを追加
最も参考になった回答
hey i just added a backlight sheet to my macbook aluminum 2.0Ghz it is done very easily. i purchased it off of ebay for $25.00, the item number is (220714814758) it should still be there....
the process is very simple, as long as you can follow instructions and apply. just to be clear you DO NOT have to replace the whole upper case....or even the keyboard for that matter....unless you want the logo on the f5 and f6 keys, like the MBP.....the original keyboard from the macbook 2.0 will work just fine...by default the macbook will recognize the f5 key to dim the backlight and f6 to make it brighter as soon as you install the backlight sheet.
the connector for the backlight is the small black one to the left of the ram, you can not miss it.... there should be no ribbon cable attached to it....since you don't have the backlight...
that connector should be there in all of the MacBooks 2.0 unibody if it isn't for whatever reasons then your simply out of luck...
follow the guide via the link:
note: you do not have to remove the LCD, HD, battery connector etc, just remove the components that will allow you to lift off the logic-board.
once the logic board is off then it is as simple and removing the black film from the bottom of the keyboard which is applied with some mild adhesive at the edges... **there will also be a clear film right under the black one, you do not have to remove that one.
now just place the backlight sheet in and re-secure the adhesive at the edges and put everything back together.... when you start up your MB the backlight will automatically be recognized....
hopefully all of your questions are answered....
ENJOY!
このアンサーは役に立ちましたか?
スコア 8
2 件のコメント:
Thanks very much for your advice Muhibmc, i'm expecting the backlight sheet to be delivered soon.
さんによる
Your suggestion is way better than mayers because it universal
さんによる
コメントを追加
From what I have read on several posts, you have a very good chance of being able to. But 15% of these machine lack the proper connector and it can't be done on this 15%. Just Google it and read the threads on this topic. Apparently Apple used different connectors on some of the non-backlit topcases for some odd reason. But there is an 85% chance yours has the proper connector
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Hi, me again.
I found an item on Ebay to replace my keyboard, with the backlit option.
I've also checked my computer and found the proper connector for the backlit option.
I'll post my feedback asap.
EDIT: i received the part and installed it on my Macbook Unibody. The backlit works perfectly which converts my Macbook into an hybrid Macbook Pro.
The operation is quite hard to do and it took me about 2 hours to do it fully.
If i can help someone else, i would be glad to do so.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I have a Macbook 13" white 2010. And I'm wanting to change the keyboard to to have a back light on it. I'm wondering what the exact process is, like which products I need to buy (new keyboard? back light pad?). Then from there, I'll probably just use the guide on this website.
さんによる
コメントを追加
I just successfully installed the backlight in my Macbook. Go carefully, mark the screws, don't try to cut corners, and you should be fine. (Cable is directional).
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
you can if it is a uni-body not a white one and yeah u need to replace all the upper case for that and it's gonna take sometime for you to change it but believe me it's worth it ;)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The White Macbook can be modded to have a back-lit keyboard, but requires frankenstein type of surgery. Bot look on you tube for white macbook with backlit keyboard and see for yourself.
さんによる
コメントを追加
Yes i just bought the backlit sheet that goes on the back of the keyboard that lights it up its really easy to do i did mine in less then 30min. bought it from a seller off ebay for $35 make him an offer for that price and he'll take it. the sellers id name is: laptopleaders item number is 290457514482 put the item number in the ebay search bar and it should come up. this is easyer then having to remove the whole keyboard or top case. here is the ebay link to the seller item:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Just bought one!! Thanks for the link, Chris!
さんによる
コメントを追加
hi everybody, i have a A1278 macbook unibody and would greatly appreciate to implement the backlit keyboard. Some of you mentioned a conector which is compulsory but only on 85% ot the macbooks. Can sb screenshot this conector so that i know how does it looks like?
thanks a lot
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have a unibody macbook aluminum, the 2ghz model so it doesn't have a backlit kb, where can i find a picture of the connector on the logic board to see if mine has it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi bagheraa, i have the macbook unibody without the backlit keyboard. I would appreciate your help on where to get the one u got from ebay and how you fitted it. Thanks. My email is laitanny@yahoo.com
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yea, bought that backlight sheet yesterday from ebay. From what i've read it just needs to be that sheet connected behind the keyboard. Can be risky so only proceed if ur comfortable taking apart your computer.
さんによる
コメントを追加
quick question. i found the backlight for the keyboard on ebay. heres the link. Will it be as easy as just installing it behind the keyboard and connecting it to the logic board. or would i have to get a whole new upper case for this to work?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I want to put in a backlight for my macbook unibody late '09 model. It took me ages searching online to find one.. eventually saw one on ebay. just ordered mine:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
muhibmc, who described correctly the whole process for upgrading to backlit, wrote at a certain point:
"**there will also be a clear film right under the black one, you do not have to remove that one."
well, after performing the same operation with success, I can tall you DO have to replace the original clear sheet instead, wich you find behind the keyboard, with the new "white-dotted" one coming with the backlit spare part.
I think you *may* even leave it and install the backlit components behind it as well, but I don't think the original backlit Macbooks feature two clear plastic films one behind the other. I guess they have the backlit only.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just installed a used Keyboard Backlight on the MacBook A1278. It works great. I fortunately have a motherboard with a connector for the Backlight. Apparently not all A1278 Macbooks have the connector, so check before you buy. I got it from ebay for $5.95 (L2 Computer Inc. NY).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can Someone please tell me how to accually install the backlight. I know you have to put in the connector but i have been stumped for a week now trying to find an answer on which layer does the backlight go.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Once you have one installed how do you get the keyboard illumination option in system preferences? I have the ambient light option for the screen dimming but not for my keyboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi,
unfortunately i belong to the 15% "lucky" guys without connector:(
would this connector helps to solve the problem?
Backlit connector
Info
Thank you
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you solve the problem? Cause i belong to the 15% too :(
さんによる
コメントを追加
I have a 2011 keyboard. Can be used for solving this?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hey guys i have the 2.4ghz macbook unibody and i cant see any settings fr my backlit keyboard although i can clearly see the led inbetween the keys. any help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 14
今までの合計 40,143
