メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.8GHz デュアルコア Intel Core i5 または 2.0GHz デュアルコア i7 (Turbo Boost 使用時最大 2.8GHz)、3MB 共有 L3 キャッシュ
Block Lines on the Display & Freezing
I get these lines and unit freezes shortly after booting into recovery or into any OS.
画像
This to me is somewhat what happens if you adjust the screen resolution & restart, these lines appear as the graphic setting switches at boot, at least from memory when I did that in the settings to help my poor vision in the past. But, this time the system suddenly freezes and the display is flickering at the same time. I don't know what system was previously installed so I am trying to start fresh with Mountain Lion or Mavericks working my way upto Catalina, at least that is my plan. There is no indication in the boot menu that OCLP was ever installed as there is no EFI Boot option, so Is this a graphic chip failure (Dead unit) or a driver issue. I did manage to run diagnostics and it gave me the dreaded EFI driver issue in the report, but then it still boots normally which is odd as if the EFI driver was the issue it wouldn't fully boot. I have reset the PRAM and SMC to no avail. Occasionally I get the 3 beep RAM issue, but it was not mentioned in the diagnostic.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi Livfe, Welcome back to the iFixit answer forum. This is definitely a GPU failure. There isn't much you can do unless you are willing to try and replace the GPU/CPU (Requires board repair knowledge) or replacing the motherboard. But it's not really worth fixing as it's 14 years old and no longer supported by Apple at all.
Happy iFixing
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yeah my thoughts also pointing to a failing graphic chip. More spare parts I guess!
さんによる
That's always a plus!
さんによる
@betatechlabsau Not when you already have boxes full of Airs lol
さんによる
コメントを追加
回答を追加する
livfe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 105
