メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
screen raised, off center, logic board tilted, not snapped in.
I took apart my iPhone 3G and after putting it back together the screen assembly is uneven and will not snap in properly. The bottom right part of the screen is raised up and decreases in height (closer to being snapped in) towards the top. i can push down on it and it kind of bounces back to its 'uneven' position. if i push down the "plasma" in the screen gets distorted or white, like when you push on a computer screen.
when removing the front assembly the logic board seems to be tilted to the right a little bit. all the screws are screwed in, i dont understand why its not snapped in. it doesnt seem like anything is in the way of it.
any ideas?
EDIT: i figured it out, explanation too lengthy to type now. if anyone has same problem let me know and i would be glad to help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
I'm curious to hear what you did. My phone has a similar problem where one of the corners is raised.
さんによる
Is it the bottom right corner? which corner? ill see if i can help
さんによる
If you could post your solution for others to see, it would be great, thanks!
さんによる
コメントを追加
1 件の回答
ベストアンサー
you need to remove the motherboard and replace SIM end in first-the motherboard sits just under the lip of the SIM opening. it's a bit tricky and you may have to try a few times. it may be that you are caught up on the edge of the camera housing.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Eric Epstein さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,598
