screen raised, off center, logic board tilted, not snapped in.
I took apart my iPhone 3G and after putting it back together the screen assembly is uneven and will not snap in properly. The bottom right part of the screen is raised up and decreases in height (closer to being snapped in) towards the top. i can push down on it and it kind of bounces back to its 'uneven' position. if i push down the "plasma" in the screen gets distorted or white, like when you push on a computer screen.
when removing the front assembly the logic board seems to be tilted to the right a little bit. all the screws are screwed in, i dont understand why its not snapped in. it doesnt seem like anything is in the way of it.
any ideas?
EDIT: i figured it out, explanation too lengthy to type now. if anyone has same problem let me know and i would be glad to help.
この質問は役に立ちましたか?
3 件のコメント
I'm curious to hear what you did. My phone has a similar problem where one of the corners is raised.
David Patierno さんによる
Is it the bottom right corner? which corner? ill see if i can help
Eric Epstein さんによる
If you could post your solution for others to see, it would be great, thanks!
Taylor Arnicar さんによる
