メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年モデルのRetina MacBookを早期にアップデートした2016年モデルの修理情報と修理ガイドです。モデル A1534 / EMC 2991
Everything replaced. Keyboard doesn't work
You know, I've been so dedicated to fix this %#*@ thing. New battery, new logic board, new bottom case with new keyboard (got two because first one was bad). new trackpad, new cables and yet...... the keyboard STILL doesnt work. At this point, with money sunk into this....I guess its just ready to retire. Not sure if anyone has had this experience, but its been pretty frustrating. Everything else works fine otherwise.
Mouse works fine... power button works fine. Just been the keyboard. I've gone through every variable I could think of.. at this point I have no clue what else there.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It is likely that the very fragile cable from the keyboard / Track pad is either not fully connected or latched down or it has been damaged which is very easy to do on these models. Be careful it did not overheat from something not fully connected or whatever as then it is truly game over as there is no cooling fans on these models and the CPU will overheat & eventually short out. I have one here that suffered the same plight.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 25
今までの合計 109
