メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
Microphone not picking up voice
recently I did a teardown to replace the trackpad, and today I could not get my audio to work on a Zoom call, which sent me down a troubleshooting path. The result is that the computer will produce sound, or register that it is producing sound, if it involves a vibration of the laptop itself, such as a tap, keystrokes, vibration of the table its resting on. I used Quicktime to confirm this. Speakers work fine. The issue is the microphone, likely its connection.
I'm assuming that I did not reconnect one of the cables properly on reassembly, so will be opening it back up, and it would be helpful if I had a sense of which cable to look at when I had it open, as the prior teardown was extensive, delicate, and time-consuming.
I used three different teardown guides as there isn't one specifically for this model (1st Gen M1 13" MBP, late 2020). The main teardown guide I used is this: MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal
Unfortunately not every cable connection is identified.
Is there a map of the internal [microphone] connections available for this (or similar) Macbook Pros?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I think you'll find the Apple Service guide more useful here MacBook Pro (13-inch, M2, 2022) Repair Manual while this is the M2 model the logic is very similar. Follow Troubleshooting microphone issues see if that gets you to the answer!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Russell Hodin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 35
今までの合計 35
